I'm looking at mapping the Browse_Push button on the Rev7 to map Load on deck 1 and 2. The problem is that virtual doesn't distinguish the difference between deck 1 and 2 with the browse push button. If I do that on deck 2, it loads the track on deck 1
geposted Fri 01 Sep 23 @ 4:32 pm
BROWSE_PUSH button(s) send the same MIDI command from both sides.
Therefore they don't belong to separate decks and it's also impossible to have them perform different actions based on the side of the controller they got triggered.
However you can try to use browser_enter as an action on it. It will work correctly if you use a 2 decks skin.
geposted Fri 01 Sep 23 @ 4:38 pm
Copy the browser push command from the Rane One mapper (this is what I did) and it works as intened...
geposted Wed 06 Sep 23 @ 2:23 pm
