I've been using Mixx and now trying to switch to VirtualDJ, but I notice that the option to make your broadcast public that is on Mixx is missing on VDJ? When I broadcast it shows as private only. What am I missing?!
geposted Fri 08 Sep 23 @ 2:03 pm
That part of hte configuration has to be handled on the site. For instance, if you are using caster.fm that's where you can set public/private options. Your provider may be similar.
geposted Tue 14 Nov 23 @ 7:50 pm
