I have to controllers SB3 and a Rev 1. I recently connected my rev 1 to virtual DJ software to try it out. I then reconnected my SB3 and now it doesn’t have any audio to my earphones and I can’t remove Rev 1 from the bottom right of my audio settings. Rev 1 works but SB3 does not. Please help
geposted Sun 10 Sep 23 @ 12:02 pm
don't know if this is what you are asking..
It is good to save an Audio configuration (or 2) for each controller you connect..
to make it easy to apply the setup that you liked and worked.
Create an SB3 and a Rev 1 audio configuration ..
following each controller's manual suggested audio setup.
Save each configuration:
by changing name in box to right of the "APPLY" button, then click the save button.
then your saved audio configurations are then accessed from the drop down menu.
hope that may help.
hope that may help.
geposted Sun 10 Sep 23 @ 12:32 pm
