So I have 1 of these little units and lastnight I wanted to play some 45's from my collection.
I set VDJ in bypass mode and starting playing a record. Everything was fine until I went to adjust the eq's.
Nothing would happen, meaning there was no change in the sound.
I switched over to SDJ and put it into bypass mode, pressed play on my turntable and tried to adjust the eq's which worked!
Why am I not able to adjust the eq's with VDJ using an Akai AMX mixer??
geposted Tue 12 Sep 23 @ 1:14 pm
When u bypass Timecode, it's like a Live Input, so Stems separation wont work. But if you set Eq mode to Frequency, it should work.
geposted Tue 12 Sep 23 @ 1:57 pm
Well damn, now that you mention it, I did have the stems on the eqs, I'm an idiot!!
Thanks for the help.
geposted Tue 12 Sep 23 @ 4:42 pm
VDJ should automatically revert to EQ in that case though
geposted Tue 12 Sep 23 @ 5:48 pm
I'll be home in a few hours and try it out again and report back my findings.
geposted Tue 12 Sep 23 @ 8:09 pm
Ok so once I switched back to traditional eqing everything is working great now 👍🏾
To Adions point, it does NOT actually switch once I hit the bypass button.
geposted Wed 13 Sep 23 @ 12:22 am
