Hey guys, I have been using vdj from 2017 and this is my issue. I would wish the option of sampling a section of a song in reverse be added in the 'sampler_rec' action. This is because most of the time when using vdj I would need to quickly edit the samples in reverse but I can only do that after playing the song and setting 'reverse on'. This method makes the sample not to be accurate and is not fast enough especially when using it in big mix projects. The other method that I have found to be pretty good but is also time consuming is using the 'Track cleaner' feature then censoring manually or is there any other way to achieve this?
geposted Tue 12 Sep 23 @ 4:22 pm
Assuming you just want to reverse part of a song then map a button to dump while_pressed
Maybe I'm not understanding what you want to achieve properly?
geposted Tue 12 Sep 23 @ 4:49 pm
I want to use it in mix creating not live mixing. So I need a way to cut a specific region of the song in reverse without playing the song, eg the Audacity style
geposted Tue 12 Sep 23 @ 4:56 pm
