Hi Guys, I have been working on VDJ triggering some other software I have on the same machine. I have mapped a key in the other software (shift+Q). Does anyone know how I can get that key built into a script to trigger when deck 1 stops? Been trying this for a few days being unsuccessful.... Outside of VDJ when the key is pressed it works, but ideally would like VDJ to mimic a press via a mapping. I can take in rest / tcp commands in the other software but aware this can't be done via VDJ....
Cheers
Cheers
geposted Tue 12 Sep 23 @ 9:14 pm
I have a thing that sends keystrokes F13-F19 & F21 plus shifted versions [shift+F20 was fussy for some reason]
I've made other stuff that sends out http over local host.
If interested send me a pm.
I could edit my plugin to actually use shift+Q.
I should add you can't do this without a plugin.
geposted Tue 12 Sep 23 @ 9:32 pm
Cheers, thanks! Dropped you a message
geposted Wed 13 Sep 23 @ 8:44 am
