Topic: stems_split documentation
love the VDJ stems_split feature.
Have been using it, and it does exactly as described.
where if used on left deck, then vocals are deck 1 and instruments are on deck 3.
All was great till, the new "Stems Split 3-Band" padpage.
https://virtualdj.com/forums/254476/Addons/Stems_Split_3-Band.html
(which I also feel is awesome)
But when I first attempt to split stems, using the "split" button, below the vocal button, was assuming that it would create the above mentioned..(vocals on deck 1 and instruments on deck 3) but it appears the opposite, vocals on deck 3 and maybe instruments on deck 1.
Confusing ! (but that is issue for that padpage use, not really topic of this thread)
and looking at the scripts of the padpage, (to understand), there are scripts
stems_split 'vocal'
stems_split 'melody'
stems_split 'rhythm'
where can one find the more documentation for the verb stems_split ?
what stems are allowed, and their functioning?
are there other parameters that stems_split accepts besides a stem?
love this awesome script !
Build 7651
geposted Fri 15 Sep 23 @ 8:17 pm
