Forum: Wishes and new features
Topic: input gain for vst plugins
Hi,
I recently try to use vst plugins with VDJ 2023 and it s work very well ( example soundtoys rack) but:
If I set the FX options to prefader I can listen the effect in the headphone but the counterpart is if I use a delay or reverb for example when I close the fader the delay or reverb tail is cuted also.
For this scenario I think if you add a gain fader (with infinite db down ) for the input on vst plugin we can product this type of effect without touch the volume fader but the gain input fader on vst plugin.
thanks
geposted Tue 19 Sep 23 @ 12:59 pm
geposted Tue 19 Sep 23 @ 1:03 pm
You re the best, the most usefull plugin in VDJ
I m not use the regular fader for volume now.
Thanks
geposted Tue 19 Sep 23 @ 4:41 pm
