Quisiera saber si puedo usar los stems 2.0 en tiempo real con esta máquina
geposted Wed 20 Sep 23 @ 3:53 am
Simple answer is no.
I have the same machine and it's too slow for realtime stems. They do calculate but not quick enough to be any use live so I use precompute instead.
Using a 3:30 track they calculate at just over 8x so it takes approx 25 seconds to fully complete in realtime. That's in bootcamp with Windows 10 but I assume the Mac side would be similar.
geposted Wed 20 Sep 23 @ 5:54 am
As per our System requirements (for Stems) https://virtualdj.com/wiki/Minimum%20system%20requirements.html
- macOS 13 or newer
- M1 or M2 processor with 16GB RAM
is required for real-time Stems 2.0 on Mac
- macOS 13 or newer
geposted Wed 20 Sep 23 @ 6:13 am
Why would x8 not be fast enough for realtime use?
It means it only takes 1 second to start playing from the start, or 2 seconds to start using stems if you seek to near the end of the song before fully loaded.
On the mac side it would indeed not work due to additional requirements there
geposted Wed 20 Sep 23 @ 6:43 am
