Can anyone help with mapping effects to the pads on the Denon Prime 4 ? It seems the only way on the prime 4 is to edit the mapper and point the buttons to the pad page xml. Its not an option to do it in the GUI . Has anyone been able to map effects in this way to the pads on the Prime 4?
geposted Wed 20 Sep 23 @ 4:34 pm
