Hi,
When I use vst effect, if I activate the effect and disable, when I reactivate this effect, I can hear a click/pop.
I confirmed this by vumeter with the test below:
1: play a track
2: enable effect 1 with soundtoys phase mistress vst
3: wait 5 senconds
4: disable effect 1
5: wait 5s
6: stop the music
7: enable effect 1
I can hear a click/pop and view on vumeter
It is anoying because few effect retrig the lfo/envelope when the effect is enable.
For example when you enable phase mistress plugin the phase/flanger restart the sine/saw when it is enabled.
If this problem can be solved in the future I think I will switch to VDJ because the possibility to use VST effect is amazing.
Thanks
1: play a track
3: wait 5 senconds
4: disable effect 1
5: wait 5s
6: stop the music
7: enable effect 1
Thanks
geposted Thu 21 Sep 23 @ 2:48 pm
