Topic: Ventura
Does virtual dj support macos ventura 13.6
geposted Fri 22 Sep 23 @ 1:34 pm
Yes, it has done since Ventura was introduced a year ago, check my system specs below.
The next iteration of the Operating System called Sonoma is due next week. I will be updating to that as soon as it's available. 😊
My Systems Specs;
Main - M1 MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.6, VirtualDJ Early Access v2023-m b7682.
Backup - MacBook Pro 15-inch 2018 (Touch Bar), 2.9 GHz Intel Core i7, 16gb 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Ventura 13.6, 500gb SSD. NTFS for Windows installed. VirtualDJ Early Access v2023-i b7682.
+ Bootcamped with Windows 10 Pro Vers. 22H2 x64bit. VirtualDJ Early Access v2023-i b7682.
