Topic: Sample Bpm
How to use sample or modify bpm in the samples slot? ...
Imagine in pad 1 a sample in 130bpm and pad 2 (132 bpm) how to modify The bpm to equal?
And NOTE im saying using only the sample mode, not playing any track in decks ( I know the sample sync with decks)
geposted Fri 22 Sep 23 @ 7:26 pm
Not sure what you are after, but here are a couple of ideas.
1. Since Sampler is synced to Decks, simply have a Track on a Deck playing at the BPM you need all of your Samples to play at. No need to have its Volume up , if no other Deck is playing, so all u hear is the Sampler
2. You can load a Sample to a Deck, adjust its BPM to the value you want with the Pitch fader, then record in VirtualDJ and then replace the original with the recorded one.
