Good evening,
I'm looking for a way to keep the deck faders in sync for volume. So if I raise Deck 1 louder, Deck 2 should automatically go to the same volume. Is there such a setting or can I set it up with the mapping?
geposted Tue 26 Sep 23 @ 7:42 pm
Yes, that is the auto gain
Maybe this will inspire you:
geposted Tue 26 Sep 23 @ 7:45 pm
