Hola - Mac m1
Trying my hand at plugin development, making slow progress but I've got the example working of audio-plugin-dsp-example-2
Is there an example anywhere that shows how to make use of buttons, or create your own interface? Sliders, toggle switches etc.
What I'd really like to do is have a http request spitting out to localhost every few seconds, with the current key of the deck - but I'm a while a way from that I think.
geposted Wed 27 Sep 23 @ 8:01 am
For a user made interface there's
https://www.virtualdj.com/wiki/Plugins_SDKv8_Example4.html
for all plugins sliders/buttons are made in OnLoad with DeclareParameter_
you can see the available types in vdjPlugin.h
params =
the variable it controls,
the id OnParameter() will use if you need to do stuff when interacting with it,
the dial name shown on the fx gui,
a short name shown some places on the skin,
the default value of the variable if you double click the dial, or if an .ini file isn't available to save the dial position between sessions.
each type of "thing" button/switch/slider etc is mostly the same params with minor differences. dials use float, buttons/switches use integers, buttons don't have a default value because a button is momentary.
HRESULT VDJ_API CMyPlugin8::OnLoad()
DeclareParameterSlider(&m_Wet,ID_SLIDER_1,"Dry/Wet","D/W",1.0f);
return S_OK;
params =
geposted Wed 27 Sep 23 @ 3:10 pm
NetworkControl plugin maybe directly?
http://www.virtualdj.com/wiki/NetworkControlPlugin.html
Then javascript
geposted Fri 29 Sep 23 @ 5:46 pm
