Topic: Camera
How would I map the camrea "ZOOM" knobs?
I want to create a pad page with different camera zooms.
Thanks for any info.
geposted Wed 27 Sep 23 @ 8:48 pm
depends on which slot you're on for the exact script but
on deck
effect_slider camera 3 VALUE
maybe
deck master effect_slider camera 3 VALUE
or
effect_slider audioonlyvisualisation camera 3 VALUE
Ok awesome! I'll check into it this weekend.
Thanks again.
Hi There First post here!. Does anyone know what the camera is called in the mapping? in VDJ8 , or can tell me the mapping i need to enter to switch a camera on & off by the keyboard on my Laptop Thanks in advance Mark
depends on which fx slot you're wanting the camera on, there's 3, on deck [will mix with video crossfade], on master, or on audioOnlyVisualisation slot [the slot that says "source" under the drop down]
deck 1 video_fx camera toggle
deck master video_fx camera toggle
effect_active audioonlyvisualisation camera toggle
that's on/off, but for camera switching [over several cams], I'm not sure, I know a way, but I'm not sure if it's the best way, [and I have experimental ideas if you could change with effect_sting calling a specific name]
best you answer what slot, and we can work from there
@devs, anything like camera_select +1 ?
Hi Thanks for the reply what i wanted to do is map it like you would with samples to one of the keys on the key board in stead of using the master camera switch in master video effects if that makes sense do you know if that's possible Regards Mark
probably this one then
LocoDog Thanks Very Much it seems to have sorted it on my laptop camera but im now finding vdj is not recognising the camera i have i would of thought it would of just done it automatically i have a old JVC HD camcorder do i have to put some sort of driver in im guess you know about these things ? Regards Mark
Don't know, windows should be pretty good at getting drivers if it needs them.
What does device manager say about it?
win key search "device"
Might be a case that it's happy and you just need to change the camera the plugin is using [that'll be dial 2 of the fx gui]
lazy guess to presumably swap cams
deck master effect_slider camera 2 0.0 ? effect_slider camera 2 1.0 : effect_slider camera 2 0.0
Ok i may have to change input cable from Camera Thanks Mate for your help topman Regards Mark
