Hi
i just can´t find the setting, and i hope you can help me easy.
i´m just switching out my old computer to a newer one, and when I compare the settings between the old and New i can´t find the setting. i have the same version of VDJ b7651 and skin is comtroller by DennYo 3.4.2.
On my old computor the zoom/size of the waveform changes when I change the gain on that channel. On my new one, only the schratch-waveform changes, and not the big waveform.
Where is the setting for that? It should be very simpe to find, but I just can´t.
Best Regards
Fredrik
Best Regards
Fredrik
geposted Thu 28 Sep 23 @ 5:44 pm
Try "waveGrayOnKill"
geposted Thu 28 Sep 23 @ 6:11 pm
nope, that didn´t make any difference. :-(
geposted Thu 28 Sep 23 @ 6:18 pm
Solved it.
If I changed the "Main wave Type" to Schratchwave, it worked.
Yohoooo :-)
Yohoooo :-)
geposted Thu 28 Sep 23 @ 6:40 pm
