Topic: Window grab instead of screen?
Ive checked plug ins and other options but I can find something to meet my need. I dont want vdj to stream my entire screen and apply a waveform overlay. I want to choose a single window and have it stream that window specifically with the waveforms over it since my monitors are limited it would be easier to do this instead of it taking up an entire monitor and showing everything that occurs on that monitor when I switch windows.
geposted Fri 29 Sep 23 @ 8:18 am
That is what it does
It streams/broadcasts your video output window
And you fully control what is included on this video output window and where - like music video, video clips, video skin, overlays, shaders, camera and so on
This may inspire you:
The issue im having is its not a video output. I have a game I play and I want to stream the game through vdj and overlay my waveform to it. I dont want to stream the entire screen cause I may tab out to check discord and so on. So I want to select the game window only and have vdj stream it. So its not a video or image file or a camera input.
