Topic: pioneer rev 5 mapping glitch
effect number 2 doesnt seem to work on the rev5 mapping
1 and 3 work, but not 2.
at least on my controller.
i think it might be simply an issue with the mapping that might need an update.
geposted Sun 01 Oct 23 @ 11:56 pm
Are you using the FX 6 Slots view in your skin ?
Any chance the srlected FX on Slot 2 is also selected in another Slot (1 to 6) ?
there is no effect selected on any other slot
when using all 6 slots. 1, 3, 4, 5, 6 all work, just 2 doesnt turn on, regardless of what effect is loaded into it.
when i switch to just 3 effects slots, then 1, 2 ans 3 all work on both decks
ok it just magically started working now, after flipping over and back between 3 and 6 slots....
must be a case of technician proximity syndrome. ah well....
