Topic: Need to download virtual DJ 2018
I hope someone can help me. I need to download virtual dj 2018. my back is an old computer and 2018 is the newest version it can run- hope someone can help!
Thanks everyone!
geposted Mon 02 Oct 23 @ 1:03 am
OR you could just fully disable Stems 2.0 and away you go.
the only real difference is you might want to run the 32bit version - also available on the builds download page, or just run 2023 with stems 2.0 fully disabled. i run the 32bit version on the clubs' computer and it's a windows7 dinosaur and the 2023 on my laptop from 2014 that just isn't powerful enough to run stems 2.0.
your computer CAN run VirtualDJ 2023. you just don't think it can. and haven't given real troubleshooting details to show otherwise.
Just go get the latest 32-bit version. Your OS may even be 32-bit, and then that is the only one that will run
It doesn't even have stems, so nothing needs to be disabled
And it doesn't really use more resources than VDJ2018
