Topic: Build 7692 bugs and improvements
Hello. Here on the latest early release 7692.
1. VDJ is taking a bit longer on startup 12secs on average(had to use a stopwatch), while indicating something downloading..." Downloading Oauthlogin +27more...". Before it was an average of 4 seconds. Would'nt want Atomix to go down Serato's wait time for it to load all my 8TBs in the long run.
Note: Happens with a 5TB external hard disk connected at startup, without it average 6secs. This was not the issue in earlier builds.
2. The loopout effect is not visualized on the graphic wave as before, but it is implemented.
**Edit: the loopout visualization sometimes shows up, sometimes not.
The Good:
Tidal songs are now downloadable with Hifi-Plus, really great as I have that sub.
Rolling back to 7607, which was the last build I had, if standard build 7651 has the same issues.
Specs for reference: OSX 10.13, 16GB, i7, 1TB SSD, 5TB Lacie
Thanks
geposted Fri 06 Oct 23 @ 1:14 am
