Topic: stems and loop length
Stems and maybe more will not operate within a small loop. (generally less than 1 bar.)
They will ! operate as normal if you lengthen the loop, then shorten it again.
Using full stems on knobs with fast rtx machine. The issue is new to last two updates or more.
geposted Fri 06 Oct 23 @ 9:37 pm
I cannot reproduce your result..
If I play a track .. then preset the loop length to, 1/2 beat, & w Vocal only, stems (with upper EQ Knob fullly clockwise) and then engage the loop..
I hear the vocal stem looped.
(same result with 1/4 beat set)
If I shorten the loop to 1/8 or 1/32 its become more of a buzz tone .. (which is result of short loops)
The track has pre-computed stems
Note: Tidal tracks no longer allow stems separation.
Win 10
Build EA 7692
Thanks. After last performance, I was also unable to reproduce the same.. I will let you know if, or when it happens again. It has happened on more than one occasion. Now I am aware I should be able to find a more definite cause. Again thanks.
