Topic: backup proceedure
I am using two computers, one home computer and one for my events
and i have a hard drive that i use to transfer my music between them
what is the most recommended software, and procedure to do this transfer and avoid any glitches or anomalies?
i have been using "goodsync" and it has been doing a fairly good job so far, but i do have the occasional situation where certain songs have to be re scanned every time i backup
geposted Thu 12 Oct 23 @ 3:06 pm
I use synchredible and it works 100 percent. As long as the file structure is the same on both machines then there's no issues.
You just need to make sure the sync criteria are set up correctly.
