Topic: Master panel
I have been using Virtual DJ for a while but the system seemed to reset itself recently and a different screen display is now showing. My problem with this is that there is no longer a 'mic' button showing. I'm trying to work out how to get the 'Display panel' showing again but can't find it anywhere on the settings.
geposted Thu 12 Oct 23 @ 11:01 pm
layout options on the topbar, choose pro, you changed to performance.
In case you need to keep this layout, MIC button (along with Vol and Rec) is also available in Performance layout by selecting the Mixer Rack from the drop menu at the top
Thanks for the responses. I have now found it on the 'Performance' display - but it appears when I click on the 'Master' tab there when it was coming up on 'Audio' tab by default - so I wasn't seeing it before.
