As of Build 7716 (currently in Early Access), you can set the 8 Hotcue buttons of the CDJ-3000 to Hotcues (default), Stems+FX or Sampler mode.
Additionally, when your HC buttons are set to either Stems or Sampler mode, you can enable the Split mode, so keep the 4 first buttons to control Hotcues 1 to 4 and set the buttons 5 to 8 to control Stems or Samples 1 to 4.
CDJ-3000 Mapping:
PS. Make sure you select the Factory Default Mapping
CDJ-3000 Mapping:
- SHIFT + MEMORY : Cycle through Hotcues (default), Stems+FX and Sampler modes.
- SHIFT + CALL PREV : Selects Full mode (default). When in Stems or Sampler, sets all 8 HC buttons to control Stems+FX or Samples 1 to 8.
- SHIFT + CALL NEXT : Selects Split mode. When in Stems or Sampler, sets HC buttons 1 to 4 to control Hotcues 1 to 4 and buttons 5 to 8 control Stems or Samples 1 to 4.
geposted Mon 16 Oct 23 @ 4:49 am
