Topic: swap_decks
I assigned a key to a simple command: swap_decks. When 2 songs are playing, and I want to swap the songs from deck, they swap decks but the position in the songs is not respected, and the songs are not longer in sync, which makes this function useless? What am I missing?
Thx, JC
geposted Tue 24 Oct 23 @ 6:07 am
Probably a sample rate issue [songs with different rates], try BUILD 7735 Early Access, it has a fix.
Thank you so much, it is indeed solved with the 7735 build.
