Topic: Loops with Stems
Just wondering if I can save a loop with a specific stem, i.e. can I save a loop knocking out the vocals then when I release the loop the vocals will turn back on?
geposted Tue 24 Oct 23 @ 10:41 am
You can do that only with action POIs
So, set up an action poi on the start of the loop and use something like this:
loop ? nothing : stem "vocal" 0% & loop 4
Then move a few ms AFTER the loop out point and set up a second POI and use this script
stem "vocal" 50%
thanks
