Anyone know how to add your own Fx?
geposted Fri 27 Oct 23 @ 9:55 am
https://virtualdj.com/wiki/howtousevsteffects.html#:~:text=Add%20a%20VST%20to%20VirtualDJ,VirtualDJ%2FPlugins64%2FSoundEffects%2F.
geposted Fri 27 Oct 23 @ 9:57 am
Yes kind of. I use audacity to edit any sound FX and make sure sound is clear and high enough then drag and drop it in sampler on right hand bottom corner and there u can select which pad to place it on.
geposted Fri 27 Oct 23 @ 12:32 pm
