Topic: Equalisers stuck on 'frequency' mode
Hi all,
I updated to v7692. The equalisers now reset to "frequency" (high/mid/low), whenever I drag in a track.
There is still a tick next to EXremix in the drop down menu, which is what I want to select. But it is only working in frequency mode - the tick is incorrect. I have tried this on multiple tracks.
The stems on the pads are also not working correctly.
I reinstalled the previous version (7651) but the same problem is continuing.
Is there an option that has reset somewhere, or other fix?
Thanks for your time!
geposted Sat 28 Oct 23 @ 4:21 am
If you are using Tidal, note that Tidal no longer allows stems to be used.
Thanks.
Are there any other options for hobbyist DJs, besides buying every track?
