Topic: Latest Update Grid Issue
OS: Windows 11
VDJ Version: 8.5.7746.0
Skin: V8 BUT BY FRUIT
Licence: VirtualDJ 2020 Home PLUS License for DDJFLX6
After the recent update the grid lines extend below the normal area and are really messed up. Have tried reinstalling and deleting settings.xml, but as soon as I enable grid it happens again.
Any advice how to fix this?
geposted Mon 30 Oct 23 @ 6:11 pm
It should probably be fixed in the skin, but until that happens you could set experimentalSkinEngine to No
I thought Fruit had stopped contributing and none of his work would ever be updated.
Hi Adion,
Thanks for the speedy reply.
I have changed that setting and although the grid still extends below it's at least usable now.
Many Thanks,
Ian
Hi KRADCLIFFE,
Thnks for the info.
Latest update is 2017 I think so that seems plausible. Would be a shame as the skin is really nice, should probably start looking at alternatives though as no doubt it will stop working at some point.
Ian
Other than a change to when experimentalSkinEngine is enabled there hasn't been a change though, so with that set to No it should be the same as in previous versions.
