Topic: Flashing Icons
Hi folks, I just downloaded the latest build, b. 7746 and all the icons to the left of browser keep flashing. Any idea why this might be? I'm using a PC running Windows10! I also downloaded it on a Mac with no issues! This build is the first time I've seen this happen. Any help is appreciated! DJ JoeB.
geposted Mon 30 Oct 23 @ 10:42 pm
You are using the 64-bit version right?
Can you try if setting experimentalSkinEngine to No fixes it?
Thank you so so much! Setting experimentalSkinEngine to no solved it! Your help is greatly appreciated!!!!
I notice this also with other few lower versions and did not really care about it.
I had mine set to Auto for so many many years, and never had this happened.
Changing the setting to NO made the flashing go away.
Were you using the 32-bit version perhaps?
Hi Adion, no I only use the x64 version.
The Flashing I notice was the VIRTUALDJ Logo on top left and the COG for the Silversleek Skin.
But changing the experimental to NO made it go away (I always had it set to Auto).
I did not try the 32bit version (virtualdj8_beta (x32) v7609).
That's the last version I have for the 32bit.
