My micphone works when its plugged in comes out clear but when i record virtual dj isnt picking up my micphone with my numark pro fx 2 chanel 4 way controller how do i get vdj my micphone to connect and work please
geposted Fri 03 Nov 23 @ 2:28 am
https://virtualdj.com/manuals/hardware/numark/mixtrackprofx.html
* Note : The Microphone Input is directly routed to the Master Output of the Mixtrack Pro FX. The input is not available in the USB Audio Interface, therefore it cannot be included in the Audio Setup nor can be recorded directly. However, recording your mix along with the Microphone Input is possible via Record LoopBack
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Fri 03 Nov 23 @ 2:36 am
OK
geposted Fri 03 Nov 23 @ 7:26 pm
