My bad: PITCH LOCK (can't edit title)
It's probably something stupid, but my left (A) deck will not pitch lock. Both A/B "Pitch lock" icons are on and the right (B) deck maintains a pitch lock. However, the left audibly bends the key up or down as I move the pitch slider.
This behavior occurs with and without my controller (NS7ii) connected. I checked the "Pitch lock" icon in the mappings and it is assigned to "pitch_lock" for both A/B decks.
Any help is much appreciated.
geposted Fri 03 Nov 23 @ 3:33 am
          pitch_lock is sliders linked together and has no bearing on key.
master_tempo is best described a key lock.
geposted Fri 03 Nov 23 @ 4:20 am
          Thank you Locodog! That was it, and it was set to per deck with only deck B checked. Appreciate it!
    geposted Fri 03 Nov 23 @ 6:11 am
