Topic: CDJ3000 and DJM900NXS2
Hi, my most recent setup is using 2pcs of CDJ3000 and a DJM900NXS2.
My question is: The player numbers are right now no.2 and no.3 in the prodjlink network (since they use mixer channel 2 and 3 on DJM)
When connecting them to VDJ, they take therefore action of "deck 2" and "deck 3".
Is there a way or setting to make player no.2 control deck 1 in VDJ and player no.3 control deck 2 in VDJ - Without having to rename the players 1 & 2.
Thanks!
geposted Sat 04 Nov 23 @ 3:15 pm
If you are using HID via LINK, no.
The number of the CDJ on the LINK network is also VDJ player.
PS: It's completely fine to have CDJs 1&2 connected on inputs 2 & 3 of the DJM.
The only thing that won't work "correctly" is the "ON AIR" indicator (RED JOG LED) on stand alone mode.
