Hi, I have a macbook pro on which the latest version of vdj repeatedly crashes on my Prime Go. I have installed an older build, but now what? How do I switch them?
geposted Sun 05 Nov 23 @ 9:33 pm
delete the exe of the new build, use the exe of the older build, that's it.
geposted Sun 05 Nov 23 @ 9:38 pm
Thank you, but where is the exe?
geposted Sun 05 Nov 23 @ 9:57 pm
you open vdj right?, that's the exe or a shortcut to it.
geposted Sun 05 Nov 23 @ 10:04 pm
@locodog I noticed that the OP is on a Mac, exe files are Windows files not Mac.🤷♂️
geposted Mon 06 Nov 23 @ 2:54 am
