Hello, how can I change the color of Minimalist UX 1 completely to blue?
Thank you
Thank you
geposted Fri 10 Nov 23 @ 1:28 pm
You need to edit the xml of the skin (Video Overlay.xml) and delete the lines 43 to 47
Then it's useful to install the Pad page to help you select the type, color etc.
If the Blue color provided by the skin is not what u want, then you can edit and change it in line 21 of the xml above
geposted Fri 10 Nov 23 @ 1:54 pm
Thanks djdad for the quick reply. Let's see if I, as an older gentleman, can get this baked. :-)
geposted Sat 11 Nov 23 @ 10:30 am
