Topic: Pioneer PLX CRSS12 issues
Have this running through my pioneer DJM V10 mixer. Analogue is fine. In digital using VDJ I can see everything on the unit match with that on the screen for VDJ but no sound or even any movement from the levels on the mixer to say it's there. I move the tempo range it can see it. Am I missing something simple? On other systems its plug and play. With VDJ everything has been a battle to set up.
geposted Sun 12 Nov 23 @ 12:51 am
Have you checked the online manual of the unit ?
https://virtualdj.com/manuals/hardware/pioneer/plxcrss12.html
If everything works fine in analog, it should also work in digital.
You only need to make sure that the "Application Mode" is set to "Serato" mode.
Also if you use VirtualDJ vinyl in analog mode, you'll have to recalibrate the DVS signal when you switch to "Digital" mode as the DVS signal is now different (the device sends Serato signal through it's audio output)
Everything working fine and works in analogue and plays perfectly on Serato program. Still nothing on VDJ in digital.
Perfect - all up and running - thank you
You have your CRSS12s running flawlessly??? No pitch slider issue?
Latest update should have solved all pitch issues with DVS (including CRSS12)
