Export virtual folders
It would be nice if you could export virtual folders including subfolders from one computer to another computer completely as XXXX.Vdfolder and then transfer these files to the new computer using an import function. That would save a lot of “work”. An extended search function that then searches for the music files on the computer that are listed in the newly inserted virtual folder would also be a significant relief.
geposted Fri 17 Nov 23 @ 3:48 pm
You can create a Backup on your 1st computer, then on the 2nd computer, you can choose to export whatever u want (incl. Virtual Folders).. https://www.virtualdj.com/manuals/virtualdj/interface/browser/toolbar/index.html#restorebackup
geposted Fri 17 Nov 23 @ 3:56 pm
