I am using the DDJ REV 5. When I scratch there is an intermittent screech sound that happens. I was told this could be a problem with the Audio buffer size. Please advise.
geposted Fri 17 Nov 23 @ 7:12 pm
increase latency setting and see if it goes away :-)
geposted Fri 17 Nov 23 @ 7:49 pm
Its currently set at 256. What should I set it at ?
geposted Fri 17 Nov 23 @ 8:18 pm
try 512 to start if no improvement try 1024 if it goes away at 1024 your going to want to fix the latency issue cause it will probably be to high for scratching
geposted Fri 17 Nov 23 @ 8:25 pm
When I go to the performance options in settings it says, "latency in samples" Will changing this setting have any effect on tracks?
geposted Fri 17 Nov 23 @ 8:38 pm
Why not just try it, and find out?
geposted Fri 17 Nov 23 @ 9:09 pm
Same here…👎🏼
geposted Sat 18 Nov 23 @ 5:19 am
