What’s going on!??…..using Macbook
geposted Sat 18 Nov 23 @ 1:24 am
so download the previous build https://virtualdj.com/download/build.html
geposted Sat 18 Nov 23 @ 6:12 am
I did and it shut down after about 30 minutes. I reinstalled both VDJ and controller driver/firmware.
Max user.
Max user.
geposted Sat 18 Nov 23 @ 6:31 am
Then I guess you have proved that it's not likely to be a VDJ reason - more likely a laptop/OS issue
geposted Sat 18 Nov 23 @ 8:42 am
Nope…. VDJ is the problem. I’m not the only paying customer ($300) who is having the same issue.
geposted Sat 18 Nov 23 @ 6:56 pm
You're not exactly giving us an information overload...
Ok if it's VDJ, what build were you running prior to this "problem" update? If that build was working, reinstall it and problem solved - surely, if it's the VDJ software.
geposted Sat 18 Nov 23 @ 7:03 pm
