Topic: Remove and reinstall issues
I would like assistance to remove the current Virtual Dj and assist with reinstalling virtual Dj.
geposted Wed 22 Nov 23 @ 4:33 am
No need to ever do that
- if you want to go to a new version, simply "install on top"
- if you want to start over with settings or your database, simply remove the xml files, and VDJ will create new ones
But if you want to keep all your settings and track info, and want to install the same version of VDJ again, don't even try. That would only replace the .exe file with the exact same .exe file, so there would be no change at all
In other words: It never helps with any issue anyone may have to keep your data and re-install VDJ. I really wish more users realized this
