Topic: directx error on launch
Im running directx 12 and cant open the prog?
geposted Sat 25 Nov 23 @ 11:19 am
Which error do you get, and which OS are you using?
windows 10 and a long message
it asks to install the correct drivers on my video card, i dont wish to use the video side of vdj, can anyone help?
the video card is used to display the program on your screen ... just update its drivers
