I created a virtual folder with 2 conditions, it contained a 'tag' for user 1 and user 2.
By mistake I selected all results in this virtual folder and did 'remove'.
The virtual folder is now empty but I'm not longer able to find all songs that were in the virtual folder by the search feature. The songs are also removed from the 'general database'.
Anyway the songs are still on my drive but there are missing in the database and off course the tag is gone.
I use only 1 drive, this can't be the problem.
geposted Sun 26 Nov 23 @ 12:00 pm
I selected the root folder and did 'Batch' - 'Add to searchDB'.
After this I was able to search all songs and the strange this is that my virtual folder again contains all songs with the tag I made before. Problem solved
geposted Sun 26 Nov 23 @ 12:07 pm
