Topic: Virtual dj with Sonoma
I installed macosx Sonoma but when I launch Virtual dj nothing is heard in the speakers. What could be the cause?
geposted Tue 28 Nov 23 @ 4:56 pm
What is the Audio Setup you apply ? Can you post a screenshot of it ?
If you use some controller, perhaps you need to re-install its drivers (if available), and also check in Privacy & Security of your OS if anything needs to be allowed.
geposted Tue 28 Nov 23 @ 5:17 pm
Solved, thanks DJDAD!
geposted Tue 28 Nov 23 @ 5:35 pm
