As you know, a Pioneer unit which has a loop active and your press a HC button, will save that as a "hot cue with loop enabled" , can VDJ replicate this behaviour by change of a setting?
geposted Sat 02 Dec 23 @ 3:17 pm
No, only by scripting.
I think this pad page may help you, as this was it's intention:
https://virtualdj.com/plugins/?addonid=80393
geposted Sat 02 Dec 23 @ 5:30 pm
Thanks Phantom!
geposted Sat 02 Dec 23 @ 7:14 pm
I usually use this workaround:
1/ save the loop using the saved loops pad
2/ go to the editor and assign it as hotcue
This way my hotcues pad works as loops too.
geposted Sun 03 Dec 23 @ 5:56 am
Good advice. Thanks
geposted Sun 03 Dec 23 @ 11:38 am
