I want audio with this configuration, send the master to music and headphones from the controller output, it doesn't work! I can't hear anything from the headphones.
The same configuration on rekordbox works perfectly, I want to use VirtualDj, I can't solve it, help me!
geposted Wed 13 Dec 23 @ 4:25 pm
Click on the DDJ-FLX4 button in your AUDIO setup to create the default audio configuration for FLX4 as seen in manual . https://virtualdj.com/manuals/hardware/pioneer/ddjflx4/setup.html
Then add a 2nd Master output using your other sound card, so have 2 Master outputs there.
geposted Wed 13 Dec 23 @ 4:30 pm
solved, thank you so much, you were amazing!
geposted Wed 13 Dec 23 @ 4:59 pm
