Hi,
I am in the midst of customizing a skin for Virtual DJ and have come across a particular challenge where I need some dvice. My objective is to dock a specific plugin, "kHs 3-Band EQ," into the pluginzone of my skin. The intent is for this plugin to automatically dock in the designated pluginzone whenever it is opened.
Currently, my setup involves a
Here is a brief excerpt of my current skin XML setup for your reference:
I am looking for guidance on how to ensure that the 'kHs 3-Band EQ' plugin GUI docks specifically within this pluginzone. Is there a way to specify through the skin XML which plugin should be docked, or is there another approach I should consider for this customization?
Any tips, insights, or suggestions from experienced skin developers or knowledgeable users would be immensely helpful.
<pluginzone>within a
<split>element named "effects." However, when I open the GUI of the 'kHs 3-Band EQ' effect using the
effect_gui_showcommand, it opens as a separate window, rather than docking within the browser panel as intended.
<split name="effects" type="horizontal" ...>
<pluginzone class="browsercolors" resizeX="yes" resizeY="yes" attachX="both">
<size width="[WIDTH]" height="[HEIGHT]"></size>
<pos x="0" y="0"></pos>
</pluginzone>
</split>
geposted Thu 14 Dec 23 @ 1:02 pm
vsts guis don't dock
geposted Thu 14 Dec 23 @ 1:30 pm
