Topic: djm-tour1 cdj-tour1
Hello Everybody,
I will soon mix in a club that is already equipped in DJ BOOTH. It is a pioneer DJM-TOUR1 and 2 CDJ-TOUR1. I have no space for install my 4 + premium denon. Is it possible to plug them into usb on my pc so that everything is considered as a controller and the sound comes out on the DJM-TOUR1 while using VDJ? Or should I use the export function CDJ in order to have all my playlists with the same information as in vdj?
The first choice would be for me the best, because I could still have the stems...
If it doesn't work for now, did you think that some devs can make the compatibility of those 2 hardwares soon ?
Best regards,
Laurent
geposted Fri 15 Dec 23 @ 9:25 am
