I have a problem with my Pioneer DJ DDJ-FLX6-GT
At first everything is alright, but after a few minutes the animation from the controller stops working (I mean the lights from the decks and pads etc.) I still can use everything knobs, decks, pads but the lights just stay frozen, and the only way to make them work again is by unplugging the usb and plug in again... But everytime I do that the music stops and that absolutely can't happen.
I've been trying to fix this through updating drivers, windows, the controller itself, but nothing seems to work.
It happens on my Laptop but also on my Desktop which is much stronger. Even tho, I changed VDJ settings to use less resources from my computers but nothing changed.
The problem persists...
Help is very much appreciated
geposted Mon 18 Dec 23 @ 4:43 pm
Did you try a different cable or USB port?
geposted Mon 18 Dec 23 @ 5:03 pm
I think That is a normal startup on that controller. You should not have to change that.
geposted Mon 18 Dec 23 @ 5:53 pm
Yes, I forgot to mention that. But yes, it happens with other USB ports/cables too
geposted Mon 18 Dec 23 @ 8:59 pm
You mean the settings?
geposted Mon 18 Dec 23 @ 9:01 pm
