Topic: Quick reconnect all equipment (shortcut)
Sometimes at home I turn off my LC6000 and my mixer without closing my vdj session on my computer.
And when I switch my equipment back on it is no longer correctly detected by VDJ and I have to go to the controllers tab, then on each of them go to the reconnect icon at the bottom right and click on 'reconnect device'.
This works very well because then my equipment is perfectly detected again without having to close and reopen VDJ.
Is there a way to create a script on a keyboard shortcut to quickly reconnect all the equipment without having to go into the options and reconnect them one by one?
geposted Fri 29 Dec 23 @ 12:57 pm
I think rescan_controllers & refresh_controller should do the trick
Thanks George
I will try asap
